Fuel Line Help
Old 03-06-2012, 02:50 PM
chewyman1's Avatar
Question Fuel Line Help
Hey guys, need help with getting fuel to my 6.2L L92. Basically same as the LS3 - I am running the stock fuel rails for now and have a 3/8" stainless steel fuel line down on the frame rail, and need to join them together. Please help.
Old 03-06-2012, 03:41 PM
Old Geezer's Avatar
If the ss line has an AN fitting on it, use a AN adapter, run hose to the rail and use a quick disconnect to AN adapter....
Old 03-06-2012, 04:22 PM
chewyman1's Avatar
No an fittings on the pipe, I wish it was that easy
Old 03-07-2012, 06:57 AM
Old Geezer's Avatar
Question How about..
Putting 1 on?? You can use a Swageloc and not have to do a flare.
Or, use a Parker that's less money.
http://www.parkeralok.com/Swagelok_A...FcPs7QoduRXGag
Old 03-07-2012, 10:16 AM
oldngray's Avatar
Default fittings
Use a 37 degree flaring tool and use the tube nut/sleeve, it is easy, and relatively inexpensive
