Chevrolet Camaro 1967-2002 - P235 55 R16 Tires
kbrewer
03-12-2012, 10:41 AM
Hi,
I am looking to get 4 new tires for my 99' Camaro V6 with 55 tire option. They are P235/55 R16. I know there aren't many choices, and it seems that the BF Goodrich have a few poor ratings. Any help is appreciated.
Thanks,
Kevin
smasher25
03-12-2012, 01:59 PM
just buy a mustang, camaro's are junk and slow
Guy2dogs
03-23-2012, 09:21 PM
kbrewer, try going down to a 50 series tire, then from there you can try a 245/50-16 or 255/50-16. go to tire rack or a web site thats the same and check the diameter of the tire. find a tire the comes as close to the oem as possible. Look on the bright side, at least you dont own a mustang, you would of put alot of money into it to it so the mustang can aleast do a minute in the 1/4 mile.
Doug G
03-24-2012, 07:55 AM
A 235/55/16 tire is ...
9.25 wide (side wall to side wall) and 26" tall (approx.)
245/50/16 tire is.... **************** 245/55/16
9.5"wide and 25.5" tall ************* 9.5" wide and 26.5 tall
You can play with sizes some to get where you want/need to be....but if you get a taller/shorter tire it can/will play with your speedometer and ABS....Just a heads up so you might want to get that fixed/programed. ;)
bww3588
03-24-2012, 01:00 PM
going from a 235/55 to a 245/50 will not change anything. any differences are too minimal.
FWIW, on my 98 S-10 with the ZQ8 option, it had factory 235's and i went up to 245's and nothing changed except my tire options.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
