Schrader valve for Edelbrock Fuel Rails
I bought a set of Edelbrock fuel rails for my motor, I'm using an adjustable regulator and i have a Magnfuel "Y" block that feeds the back side of both rails. I have both front ports plugged off. I'de like to put some sort of schrader valve on the front of one of the rails to be able check fuel pressure. I'de also like to keep it the same size as the factory GM valve rather than a smaller one. Any leads?
thanks
thanks
