LS swapped Mustangs with stock K members?
Looking for some pictures, or information of guys who have put a LSX in a SN95 Mustang using a stock K member? I need to use a stock one due to the "rules" that are being enforced. Using tubular K member is no good for me, although, it would make it a hell of a lot easier.
Thanks,
Josh
Thanks,
Josh
i have a tubular but its a 5.0 one. all i did was buy block plates off ebay and then bolted them on the motor, bolted some 1/4'' x 2'' to the k-member and used some 1 1/2'' square tubing for the "stands"
I want to build a 99+ mustang this time around, and I would like to do it without cutting into the stock sub frame, if at all possible? I Know with the 240's, the only way to do that is to get a custom made oil pan.
So, I thought I would see if anybody has done the swap with a stock sub frame? I cant imagine anybody would, as the aftermarket tube frames are pretty damn cheap (cost wise), so there isn't much motivation for somebody to keep a stock sub frame, unless their racing class rules call for it.
