Boost drop from 15-12lbs changing trans fluid?
Last week I ran my car at the drag strip and it was really loose. The only change I made this week was the trans fluid. I went from Tractor 303 fluid to type F. The car seems to have tightened up. I would have thought it wouldn't have. With the 303 fluid the car wanted to "sliiiiiide" into gear like it was a manual trans and I was slipping the clutch. I went ahead and drained the pan only and put some new Type F in it. Didn't completely pull the trans and convertor, just pulled the pan and let drain for a while. Ended up putting 6 qts back in.
The car drives and sounds the same but just doesn't hit 15lbs of boost. It now only hits 11-12lbs. Would just changing the fluid do this or is something else going on. Both turbo's are spinning, I have the same heat on the exhaust on both sides, plugs look good, car sounds and runs good. Just doesn't hit 15lbs. I have a manual boost controller that is all the way off so I can just turn up the boost controller but just wanted to make sure that a wastegate hasn't failed or something. I have a wastegate on each side and both are getting hot, just like normal. They turn into the atmosphere, not the down pipe.
Not that it would matter but I also changed engine oil from Mobile 1 full synthetic 10W 30 to Valvoline VR1 Racing Oil 20W 50
Thanks.
Thanks.
I probably shouldn't have. I put 1500 miles on it in the last month and a half. When it gets hot after a couple hours of driving I could hear the drive train a little when I opened the hood. I figured the heavier weight oil wouldn't hurt since it was hot out. Now I am thinking I should just change it back. The problem is that I don't know if it is because of the trans fluid change or the engine oil change. The 20w/50 maybe way too thick. If it is I will change it again in the morning before I take it to test and tune. I guess the 5.3 are just a little noisy and I am not used to it. The oil looked perfect when I drained it. Maybe I read too much into the valve train noisy.
