gaket and oring chart for a ls? IDENTIFY THIS O RING!
Old 03-17-2012, 03:29 PM
TermnEatr's Avatar
Default gaket and oring chart for a ls? IDENTIFY THIS O RING!
Does anyone know where a pdf file or even a web page is that has all the gaskets and o rings that a ls motor has?
Old 03-17-2012, 05:02 PM
Darkman's Avatar
I found this:
http://www.performancetrucks.net/for...umbers-428941/
Old 03-17-2012, 07:31 PM
TermnEatr's Avatar
Anyone know where this oring would go? This is on a 01+ Lq4 if it matters.
Here it is ontop of the oil pump orings so u can get a size diff
Here's a pic showing that its roughly 7/8 in diameter
Old 03-18-2012, 10:52 AM
TermnEatr's Avatar
Anyone?
Old 03-18-2012, 11:01 PM
chrisfrost's Avatar
The only place I see close at first glance is the oil pump pick up tube to oil pump o-ring but those are usually blue , red or green ,,,,,,,there are some o-rings in the TB like the idle air control solenoid valve or maybe the oil pressure sending unit or the cam sensor .
Old 03-19-2012, 06:20 AM
TermnEatr's Avatar
I have the pick up tube o rings they are in the pic above I can't figure out where this thing goes hopefully its a misplacement issue..... Damn kids!
Quick Reply: gaket and oring chart for a ls? IDENTIFY THIS O RING!
