blow thru carb?
blow thru carb?
im looking for the best blow thru carb at the most cost effective price, so used would be fine with me. my question is what type of carb should i be looking for and any other things i should note about the carb. my build is a 5.3 with fresh heads it has a stock bottom end stock cam an so on. basicly building a stock 5.3 with mild head work. i changed my plan for an all wheel drive t just an s10 chassis with a 700r4 ot a th400. not positive on the stall yet or gears but that will get figured out dow the road. any help with the direction i should go with the carb will be veary helpful thanks.
