Pontiac Firebird 1967-2002 - OE Trim Part Numbers
View Full Version : OE Trim Part Numbers
HibachiZ28
03-22-2012, 01:28 PM
I've done some searching and can't find the part numbers. I need part numbers for:
-Exterior window scrubbers (rubber trim against the window) on the door? This is located at the top of each door, on the exterior.
-The small rubber trim that is in the T-bar, both at the front and back of the top metal piece. It's maybe 2" long or so?
Can take photos if needed.
Thanks...
mrrman
03-22-2012, 03:05 PM
have you checked out the onlne catalogues from Classic Industries, they may have it
HibachiZ28
04-10-2012, 05:30 PM
I did. Didn't see it listed on Classic. Rock Auto seems a no go as well. Salvage yards in this area are LUCKY if they have one f-body. I've only seen one. It was a V6 Camaro, but it was stripped of almost everything...
