which valve springs---- i have 3 choices
Old 03-23-2012, 09:37 PM
tta656's Avatar
Default which valve springs---- i have 3 choices
I have stockers for the 5.3, then i have the Yellow springs, and i have Katech ls7 springs...
now i know this isnt the right way to determine,but squeezing the stockers by hand and the yellow springs,theres a slight diff,but these katech springs a much more stiff,they all appear to be the same height,i just dont want to mess up my zo6 cam that i just installed...
this will be for turbo application,i will get the link to katech springs and post a pic..soon
Old 03-23-2012, 09:56 PM
tta656's Avatar
Stockers with 25k miles-------Yellow unknown miles----Katech Ls7 2k miles
link to Katech Springs
http://store.katechengines.com/high-...prings-p8.aspx
Attached Thumbnails which valve springs---- i have 3 choices-stock-yellow-ls7x2.jpg
Old 03-23-2012, 11:22 PM
killernoodle's Avatar
5 coils vs 6 means the katech springs will be stiffer than the yellows with the same wire diameter. They'll probably be fine for turbo.
Old 03-24-2012, 01:53 AM
Moderator
denmah's Avatar
i use these in all my mild cammed turbo builds they work great up to 20lbs of boost so far
140 ish dollars new and use all stock hardware, ive been using them with ZR1 cams and 22lbs of boost, they work great.
http://sdparts.com/details/pac-racing/pac1218
Quick Reply: which valve springs---- i have 3 choices
