mako22
03-24-2004, 12:28 PM
ok I'm going to have to stop pretending I really know what I'm talking about and humbly pose a question: I've noticed lately my car sounds rough under 3000 rpms and sounds like it's laboring to get around. Noisy and sluggish. It does not feel "tight" even though I just put 3.73's on. Once I get to 3000, it's a totally different story - the car runs and sounds awesome and pulls hard. I'm not throwing any codes, and I'm just wondering if this sounds like something I can correct with my Predator (too rich, add timing, ets) or is it maybe something actually wrong??? :huh:
jaberwaki
03-24-2004, 05:35 PM
well start with things that dont care about WOT...
one is idle air controler.. or IAC if it gets dirty then your idle will be choppy and fluctuate... also lower rmp half gas driving can surg or buck... or just feel like powers down...
i see your an a4... possable that the gear swap would like a stall verter?
also might wanna get a/f on wide band done...
you might be rich under the curve?...
just some things to look at ...
oh yeh... when was the last time ou swapped plugs? ;)
zamboxl
03-24-2004, 07:39 PM
i have the same problem the car i way lean under wot so maibe you are runing to lean? what ever it is if you find out what it is plz post, and let me know what it was.
ps: does you car ping or knock before wot.
