need help with th350 swap
what do i need to use my stock torque arm. and what dipstick do i need or can i use my stock one. and can i use a B&M pro stick shifter.
Stock TA: look in Jegs/Summit and look for a B&M or Hurst kit for the TH350/400 swap for 3rd gens, it works on the 4th.
I bought a dipstick from Madman, high but works well!
I am using a B&M Prostick in my LT1 car, I had to get an M6 console to make it look good, that choice is yours.
I like the pro ratchet myself. You don't have to worry about the shifter hitting anything. Such as the a/c panel or the rear of the console. The pro ratchet only move an inch in both directions, and then you just ratchet it again to go to the next gear. I also used a M6 console. I cut a little hole in the boot for the reverse lockout to come through. Looks like it was made for the car. LOL
