Vengeance built C5 Z06- 879RWHP/749RWTQ- RHS 427/A&A YSI- Pics/Video/Dyno Inside
Just finished up this beautiful C5Z for a longtime customer/friend. The goal was as much power as possible while maintaining streetability. I believe we have met his goals
Modifications previously installed by Vengeance Racing
FAST 90mm Intake- Ported/Painted
A&A V3 SI Supercharger system
American Racing 1 7/8 Longtube Headers with Catted X pipe
Current Modifications
Engine
RHS Block- 4.125 Bore/Standard Deck
Callies 4" Crankshaft
Callies HD 6.125 Connecting Rods
Diamond Custom Pistons
Total Seal Rings
Calico Coated Main/Rod Bearings
Katech C5R Timing Chain with Cloyes Billet Gears
Melling Hi Volume Oil Pump
Morel Linkbar Hydraulic Lifters
Vengeance Racing Spec Blower Camshaft
Trickflow 245cc CNC 6 Bolt Cylinder heads
Cometic MLS Head Gaskets
ARP Studs Top to Bottom
Hardened Pushrods
Power Adder
A&A Supercharger System
YSI Upgrade
8 Rib Upgrade
03/04 Alternator Bracket
Drivetrain
RPS Triple Carbon Clutch Kit
Tick Adjustable Master Cylinder
GM Slave Cylinder
RPM Transmissions Level V T56
MGW Short Throw Shifter
RPM Poly Torque Tube Couple Rebuild Kit
Suspension
Pfadt Race Engineering Coilovers
Pfadt Race Engineering Engine Mounts
Pfadt Race Engineering Transmission Brace/Mount
Fuel System
RSI Billet Hat with Twin Walbro 340s
Custom Feed/Return Lines
Aeromotive Regulator
FAST Billet Rails
FIC 80lb/Hr Flow Matched Fuel Injectors
Misc
ACP Louvered Extractor Hood
Vengeance Racing Coil Relocation Kit
Vengeance Racing Billet Valve Covers
Dyno Graph
Idle Clip
Engine
Total Seal Rings
Hardened Pushrods
Power Adder
YSI Upgrade
8 Rib Upgrade
Drivetrain
GM Slave Cylinder
Suspension
Fuel System
FAST Billet Rails
Misc
Dyno Graph
Idle Clip
