Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Custom 04-06 GTO Twin Turbo Setup + MORE
Old 03-28-2012, 01:16 PM
DiabloFormula's Avatar
Default Custom 04-06 GTO Twin Turbo Setup + MORE
Category: Racing Parts
Price: $111111
Part Fits: 04-06 Pontiac GTO
Location (State): PA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
I have a very nice custom twin turbo setup for 04-06 GTO's
The Turbo setup:
2 x GT42R Turbos 74mm dual ball bearing turbos A/R-1.01
2 x Custom built manifolds 1 7/8"
2 x 3.5" Downpipes
IC Piping needs the passenger side re-plumbed as we cut the tube for the new setup.
2 x JGS Blow Off Valves
2 x JGS Waste Gates
Air to Water Intercooler
10 gallon Water Tank
High Speed Water Pump
All water lines
Return oil lines from turbo to oil pan. -12 lines I believe
This is a custom setup... Some items will either need to be relocated or removed.
1/4 mile passes... 9.1-9.4 with Big Stuff 3 shorting out on me
Should be good for well over 1200rwhp, saw over 1000rwhp on 10psi with the previous onwers solid roller 408 on the dyno before BS3 killed itself! Turbo setup has taken that GTO 9.0s on 12-13psi, Big Stuff 3 was apparently the problem all along and the reason he couldn't throw more boost at the setup.
$6000+Shipping
Next up is a custom Nasty Performance built bread bod intake manifold with engraved "Twin Turbo" on the cover. It also has ports in the back for vacuum. Opening is a 102mm.
$3000+Shipping
I am very interested in trades for high quality LT heads for a 04-06 GTO, Fast 102 Intake setup, possibly heads as well as CASH on your part.
I also have a set of 80lb injectors that I would be willing to trade for a like new set of 42lbs. They are 83# Siemens Deka EV1 High Impedance Injectors. 60mm O-Ring to O-Ring. All flow matched. About 250 miles on them.
I car this setup was going to go on is now going cam only or cam/heads only instead, so trades relating to that would be perferred.
Old 03-30-2012, 09:35 AM
Bump....
Quick Reply: Custom 04-06 GTO Twin Turbo Setup + MORE
