would you buy this boost controller
here is the boost controller im thinking of buying its not the nicest but it seems to have all the functions and is only $238 shipped brand new
$238.99
GFB G-FORCE Electronic Boost Controller
[gfb3003]
Go Fast Bits introduces one of the most comprehensive electronic boost control systems on the market with the release of their G-FORCE electronic boost controller. The G-FORCE electronic boost controller integrates split second boost response and reaction with features and fail-safe systems found on boost control systems costing hundreds more. With versatile high end features like scramble boost (with included remote switching system), Spike-Stop boost protection, six boost pre-set capability( and many others) you can’t go wrong with the G-FORCE system. The Go Fast Bits G-FORCE has the ability to accurately control in excess of 50psi, 30% higher than that of comparable systems on the market! Your street or track car will never outgrow the G-FORCE making it the stand alone boost control system you will ever have to buy. Go Fast Bits includes all necessary hardware, wiring and mounting accommodations to make integrate the G-FORCE electronic boost controller seamlessly into any cabin with attractive and effective results.
Features & Specs:
-High Boost Capability: controls boost up to 50psi (3.5bar)
-Open or Closed Loop Operation: prevents boost variations that can occur in different gears,RPMranges and atmospheric conditions
-6 Inidvidual Boost Pre-Sets: program a different boost pressure and rise rate for each gear, and select on-the-fly
-Scramble Boost Function with Included Aux Remote: program a timed boost increase when needed, remote button activatated!
-Spike-Stop Feature: helps tame boost spiking on turbocharger systems prone to spiking
-Real-Time Boost Gauge: display real-time boost in PSI, KpA or Bar
-Overboost Warning System: user adjustable warning to indicate if the boost pressure is too high.
FREE SHIPPING!!!
$238.99
[gfb3003]
Features & Specs:
FREE SHIPPING!!!
Well on paper it sounds good.
But do you need 6 boost settings ? Do you need to have the ability to use 50psi, do you need boost per gear if it can actually do it ? ( Ive seen other units claim this when they cannot actually do it )
But certainly doesnt sound like bad value at all if it works.
i just dont want to waiste my money on anything im eventually going to upgrade later.
but i will tell you how good its works i just ordered it today.
