Crankcase Pressure removal with vac. pump?
Wheres the best place to pull crankcase pressure from with a vacuum pump? I normally pulled from the pass. side valve cover and then decided this year to pull from the other valve cover but wondering if I should go that route or pull from the valley cover? If your pulling it thru the heads it seems like you would could pull it easier from the valley? Just curious to see what others are doing, thanks.
