Pulling heads off my Suburban 5.3- info on removal?
Old 04-02-2012, 08:51 AM
Blackfly's Avatar
Default Pulling heads off my Suburban 5.3- info on removal?
Trying to remove my 706 Heads from my pulled Suburban 5.3.
How do I pull the (4)15mm bolts that reside under the rocker rail?
As the bolt backs out, my socket becomes wedged underneath the rocker rail.
Also, What tools do I need to pull the rockers and springs?
Old 04-02-2012, 08:56 AM
FasTimeSS's Avatar
Rockers gotta come off......
Old 04-02-2012, 09:29 AM
Mike96z's Avatar
rockers and rails gotta go first.
Old 04-02-2012, 09:30 AM
Mike96z's Avatar
Rockers are a 10mm I believe
Old 04-02-2012, 02:48 PM
carlos sauceda's Avatar
Rockers come right off u dont need to remove the springs. If you do end up removing springs you will need a spring compressor.
Old 04-02-2012, 03:00 PM
5w20's Avatar
rockers and rails come off.
8mm
Quick Reply: Pulling heads off my Suburban 5.3- info on removal?
