Question for Improved Racing re: Low Profile Oil Cooler Adapter
Old 04-02-2012, 04:43 PM
Mark2002's Avatar
Question Question for Improved Racing re: Low Profile Oil Cooler Adapter
I have a question regarding the new Improved Racing Low Profile Oil Cooler Adapter
Regarding the 1/8" NPT ports on the front-lower and bottom edges of the part, which line is each ported to? Does the front-lower port to the "OUT" line, and the lower port to the "IN" line??
Thanks!
Mark.
Old 04-03-2012, 04:52 PM
LS1Tech Sponsor
ImprovedRacing's Avatar
Thanks!
Mark.
That is correct. The one near the OUT port is best for oil temp. The other one is best for oil pressure or a turbo oil feed line. When installing a sensor in the port near the IN line, make sure it doesn't protrude more than 0.4" into the adapter as this can restrict oil flow.
We now have an instruction manual up, take a look at page 2: http://www.improvedracing.com/manuals/IR-EGM-1006.pdf
If you have any other questions, let us know.
Thanks!
Michael
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old 08-02-2012, 12:25 PM
imma_stocker's Avatar
Looking to add an oil cooler here. Does the low profile piece have a built-in thermostat?
Old 08-02-2012, 03:36 PM
LS1Tech Sponsor
It does not. We are working on one with a built-in thermostat, but it won't be as slim.
__________________
Quick Reply: Question for Improved Racing re: Low Profile Oil Cooler Adapter
