Are valve spring kits for 317 heads the same as stock?
Old 04-03-2012, 02:21 PM
Ws6power1's Avatar
Arrow Are valve spring kits for 317 heads the same as stock?
I just realized when I ordered my prc double spring kit I ordered it under the ls1 section. I'm doing a 317 heads swap with my cam. Do they use the same spring kits or do I need to call and change my order??? Thanks
Old 04-03-2012, 10:09 PM
TVWilkes's Avatar
Yes, 317 heads use the same kit as the ls1.
Quick Reply: Are valve spring kits for 317 heads the same as stock?
