1-kwik-6
04-05-2012, 09:33 PM
I was putting together the new 9'' tonight and I'm still a bit confused on the bearing/seals the ones they sent are different than pics Iv'e seen so I just want to verify. So if you guys can help it would be great, I know the red colored one on the left goes in the tube first. but what about the bearing that has the rubber cap? which direction does it go? rubber cap side out? then the "press ring" (right in pic) is last to go on the axle and stays on right?
this is the only logical way I can figure they will go just don't want to mess up new parts. Thanks in advance guys.
EDIT: I got it; how I figured was the right way.
