highcomp with Bolt ons
Old 04-06-2012, 12:15 AM
blow thru's Avatar
Default highcomp with Bolt ons
Hi guys im currently running all bolt ons on my Ls1 and i want to get this thing to run as hard as i can without goin cam as i like to fly under the radar,now im thinking of shaving the heads 30-50 thou to bring the comp up to around 11-1 and running e85 to pump the timing in.Do you think ill be wasting my time and money??mods are 1 5/8 4-1s, twin 2 1/2 ,otr,3.9 gears,m6.
cheers
Old 04-06-2012, 02:03 AM
01transampower's Avatar
If you plan to pull the heads then i would say ditch the stockers and get a set off 243's or 799's (same thing). They flow way better then stock and will increase power as well. No need to mill them at all just swap them. Plus I would talk to your tuner you may need to bump the injector size to a set of 32's or bigger for the E85.
Old 04-06-2012, 02:44 AM
blow thru's Avatar
Yes i realise i will have to go bigger on the injectors and good point about the 243s.Its either stay with bolt ons or if i cant make the power then cam it will have to be.
Old 04-06-2012, 10:02 AM
The heads would net you about 20 horse power or so. Then the e95 well idk how much youll net from that but im sure itll be quiet a bit. They do make mild cams that you can't even tell are in the car, 224r or something in that range would get you what you want and with a high lsa keeping the lobe some what stock you wont even hear it.
Old 04-07-2012, 12:45 AM
blow thru's Avatar
Yeah ive decided to just go the cam route,make more power anyway.
cheers
Old 04-07-2012, 12:53 AM
No problem enjoy the cam and let us know what you go with. You'll love the power and gain of your new cam.
Old 04-08-2012, 09:32 AM
Grr
Grr's Avatar
Get a set of advanced induction 243s and run a .040 head gasket and the stock cam. that setup will make as much or more power than a cam only setup and 30wtq more at low rpm
Old 04-08-2012, 10:14 AM
baxsom's Avatar
advanced inductions does a high comp 241s that are supposedly good for some real nice power
Old 04-09-2012, 10:55 PM
blow thru's Avatar
Ill start gathering some parts and then get EPS to spec me my cam.I like the 222/226,but i wont make that my choice as the boys at EPS are the masters.
Quick Reply: highcomp with Bolt ons
