Gears & Axles - moser 9 inch
View Full Version : moser 9 inch
cfiester
04-08-2012, 04:14 PM
Went to install my moser 9 inch in my 01 bird. tried to install the torque arm to the axle housing. I have a edelbrock adjustable torque arm. The bracket wouldn't fit to the cast piece moser welds to the 9 inch hsg. The stock torque arm wouldn't even bolt up. does moser supply a bracket? Just looking to see if anyonelse has ran into this.
SS SLP2
04-09-2012, 07:42 AM
not quite sure I understand " what will not fit" I had no problem fitting after market or the stock arm onto the moser housing, did you try a " dry fit arm/housing " before install housing under car?
my install did require a little clarance on the drive shaft tunnel to prevent bumping
Johnny
Valkyn
04-09-2012, 09:30 AM
Does the mount look like this?
http://pontiacgroup.com/warpedtepeepics/94bird/moser9-3.JPG
SS SLP2
04-09-2012, 12:53 PM
yep, describe what will not fit, your ta bracket drill wrong ?/too norrow?your bracket too wide ?
Johnny
projectX
04-09-2012, 12:57 PM
Details...details... lol
cfiester
04-11-2012, 01:02 AM
Yes Valkyn it is the same bracket you show a pick of. If you try to slide the edelbrock torque arm mount onto the mount, the holes will not line up because the mount is to thick. The plate hits the mount not allowing the holes to lineup. If you look at the edelbrock setup it only has 1/8th inch clearance from edge of bolt hole to side plate. the moser mount is 1 inch from edge of bolt hole to outer edge.Thanks for the help guys i am going to have to buy a different adjustable torque arm.
