BlackWS666
04-09-2012, 10:24 PM
I got a tank with a 0-90 ohm reader, and switched it to a 40-240 unit from nasty and installed it, and it works fine just is reading wrong when in the tank. When the car is pumped full it reads about 5/8 full, and empty is around 1/2 tank. Anyone else had this problem???
I already tested the gauge, its fine. Tested the sender tilted it upside down when out of tank and all worked fine. Same as when upright it reads empty on the gauge.
