66 buick skylark 5.3L, 76mm, th350 and E85
Old 04-10-2012, 08:39 AM
stocks10's Avatar
Default 66 buick skylark 5.3L, 76mm, th350 and E85
Hey everyone. I am starting my build and have a quick ?. What are you guys using for throttle cables on cars that have a mechanical linkage?
My setup is a 1966 buick skylark 4dr. 5.3L, ls6 cam, ls1 intake, 76mm turbo, th350 and E85. I will be posting pictures as I go with it.
Thanks in advance for all the help on here. I am looking forward to this build!!
Old 04-10-2012, 12:06 PM
3D87C4's Avatar
Subscribed.
My parents have always lamented the loss (cracked aluminum block) of their Skylark.
Looking forward to pics.
Old 04-10-2012, 12:51 PM
2165 Turbo Rail's Avatar
i used a lokar cable in both the 60 Chevy sedan delivery and the 69 GTO
Old 04-10-2012, 01:46 PM
rockytopper's Avatar
lokar cable here ^
Old 04-10-2012, 04:11 PM
stocks10's Avatar
sounds good thank you
Old 04-10-2012, 04:16 PM
stocks10's Avatar
figured I'd throw a picture of the car on here to start with. The appearance of the car will remain the same except for a set of color matched ralley wheels with chrome rings and center caps. I wanted to keep the factory wheels and hubcaps but they are only
14" wheels and that limits the tire size. I want to run a 235/50/15 drag radial on it. I am considering doing a white wall to the tires though to keep the grandpa look to the car
The trans is a reverse valve body, so I will need to modify the column shift to work with the 3 speed trans, it was a factory PG car.
Old 04-10-2012, 04:49 PM
Beyond Static's Avatar
Does the Skylark have the steering draglink behind the front crossmember? I just did a 5.3 swap in my '65 LeSabre, and it was a huge PITA.
Old 04-10-2012, 04:59 PM
stocks10's Avatar
no it's in front of the cross member. still looks like it's going to be tight in there with the tie rod ends to oil pan clearence
Old 04-10-2012, 05:58 PM
y5mgisi's Avatar
Subscribed!
Old 04-10-2012, 06:21 PM
67Skylark's Avatar
Thumbs up
GOOD LUCK with the build. Love the 66/67 Buick A-Body I'm going to get serious about sticking an LY6/4L85E into a 67lark the next few months.
Quick Reply: 66 buick skylark 5.3L, 76mm, th350 and E85
