Clunking when putting it into gear
Old 04-10-2012, 09:49 AM
beastlyredz28's Avatar
Question Clunking when putting it into gear
Hey guys i have a 2002 camaro z28 m6 and i just recently put 4:10 gears in my rear end and changes my drive shaft to a steel one and idk why this is happening but when i first start the car and put it into gear it kind of sounds like it clunks but it only does this when the car first starts. any suggestions should i be worried?
Old 04-10-2012, 02:11 PM
VinR1's Avatar
driveshaft u-joints would be my first guess
Old 04-10-2012, 02:14 PM
metalmilitia606's Avatar
Yep. Sloppy U-joints or a bad tranny mount.
Old 04-10-2012, 02:16 PM
devic's Avatar
yeah when my tranny mount went out it would clank the bottom of the car, also had gar problems before, ended up need a whole new rear end, my want to have them gear checked out
Old 04-10-2012, 02:17 PM
oddwraith's Avatar
Universal joints. Tranny mount will clunk/thump when you get on it, not just when putting it into gear/disengaging the clutch. Start with u-joints, work to tranny mount, then post back.
Old 04-10-2012, 10:09 PM
twitch32's Avatar
If it makes a clunk noise when you put it in to gear from neutral all the time, it could be that you have slack or wear in the axle and/or spider splines. My car does this also and I have been through the driveline several times. I always come back to the excessive play in the axle to spider gear splines.
Old 04-15-2012, 05:27 PM
hey guys thanks for all ur help it was my universal joint that needed to be replaced
Quick Reply: Clunking when putting it into gear
