FS: 3 in 1 Black Face Exhaust Temp and Digital Boost and Temperature Gauge
Category: Accessories
Price: $150
Location (State): AL
Item Condition: Brand New
LS Engine?: Fits LS Engine
$150 shipped to you
The box is unopened. Here is exactly what their website says...
GlowShift’s 3-in-1 Diesel Combination Gauge allows you to easily monitor your diesel trucks most vital engine functions, and is essential for any diesel vehicle that is driving extended distances or towing heavy cargo. This 2 3/8th inch (60mm) diesel combo gauge features an analog pyrometer readout from 0 to 1500 degrees Fahrenheit, blue digital boost pressure reading from 0 to 60PSI, as well as giving you the choice of monitoring either your transmission, oil, or coolant temperature from 68 to 302 degrees Fahrenheit with a second blue digital readout. This diesel gauge offers some incredible features that include stepper motor technology, 10 color through dial lighting, an easy to read illuminated red needle, as well as a magnified lens that allows you to clearly see all gauge readings.
GlowShift’s 10 color through dial LED lighting system lets you easily cycle through 10 solid color modes, along with 2 color cycle modes, and for easier night driving the gauge can be dimmed 30% when connected to your factory headlight switch. With the included color memory recall feature you don’t need to worry about adjusting the color of your gauge face every time you turn your truck on. This 3-in-1 Diesel Combination Gauge includes a type k thermocouple EGT probe with 6 feet of steel braided cable and a 2 foot sensor wire, an electronic boost sensor with 8 foot sensor wire, along with a 1/8th NPT electronic temperature sensor, with 8 foot sensor wire, that is used to monitor either your transmission, coolant, or oil temperature. The included 1 ½ foot power wire and all sensor wires feature modular connectors that easily clip into the back of the gauge ensuring your connection is completely secure. This diesel combination gauge can be mounted using the included dash pod or you can purchase GlowShift’s vehicle specific 3-in-1 A-pillar Gauge Pods and mount it directly to your trucks A-pillar for easier visibility. GlowShift stands behind all of its products by including free lifetime technical support and a one year limited warranty with every gauge purchase.
2 3/8th Inch (60mm) Black Gauge Face with Magnified Lens
Analog Pyrometer Readout from
100 to 1500 Degrees Fahrenheit
Blue Digital Boost Readout from 0 to 60PSI
Customizable Blue Digital Temperature Readout
from 68 to 302 Degrees Fahrenheit
Type K Thermocouple Probe with 1/8th NPT Threads,
6 Feet of Steel Braided Cable, and 2 Foot Sensor Wire
Electronic Boost Pressure Sensor with 8 Foot Sensor Wire
Electronic 1/8th NPT Temperature Sensor with
8 Foot Sensor Wire
Stepper Motor Technology
10 Color LED Through Dial Lighting with Color Recall Ability
2 3/8 Inch Dashboard Mounting Pod
Mounting and Installation Hardware
Free Lifetime Technical Support
One Year Liminted Warranty
