a338566
04-12-2012, 09:34 AM
The fuel pump died yesterday and i will be installing a racetronix with a hot wire kit in the next couple of weeks, what other components should i be looking at while i am working on the fuel system. The car is full bolt ons for now, heads (AFR) and cam (mild lope) are on the plans for the winter storage coming up in 2012. ANy suggestions or input is appreciated
TransamGCS
04-12-2012, 07:01 PM
your racetronix pump should come with two different sock filters so make sure you change that i would look at replacing the pressure regulator and check the the fingers on the fuel sending unit for corrosion or brittleness
sjsingle1
04-14-2012, 11:01 AM
my racetronix only came with 1 sock filter.......had to go to the dealer and get the other 1......if i had it to do all over again i would get a NEW complete stock bucket assembly from RT .....they have the best price i have seen.............and put the RT pump in the new assembly
