Fueling & Injection - 6.0 Vortec Intake with 160lb bosch injectors?
chris406
04-12-2012, 11:05 AM
Done some searching and haven't been able to interpret a correct answer. Will 160lb Bosch low impedance injectors fit a stock 6.0 Vortec Truck intake? I'm not concerned about fuel rails only whether or not the injectors will fit correctly in the manifold bung and be positioned correctly for proper fueling.
Thanks
FICINJECTORS
04-13-2012, 07:32 PM
Thanks
The injector will fit in the intake. They are both std 14 mm . The rails will have to be spaced up to 60mm
