cts-v oil pan and ls swap mounts?
Old 04-14-2012, 10:58 AM
greenturtle05's Avatar
Default cts-v oil pan and ls swap mounts?
Time to start purchasing some parts for my swap. Wheres the best place to purchase a complete cts-v oil pan? Also need swap mounts to install an lq9 in an 83 Caprice. Thanks
Old 04-15-2012, 03:29 PM
What about Dirty dingo mounts?
Old 04-15-2012, 03:48 PM
rail2k's Avatar
i purchased mine from jegs or summit for 150$ came with everything its called the muscle car pan its supposed to fit any older model gm frame my vehicle is a 73 nova. As far as mounts go im having mine made from a template i found on here but i would check with some other members maybe they will chime in on your application
Old 04-15-2012, 07:15 PM
99VetteFRC's Avatar
I used standard mounts I bought from Summit for $45 but had to move them back about 1.5" anyway. Used a CTS-V LSA pan I got off Ebay for less than $200 and it came with pan, widage, dipstick and tube, and gasket. No bolts however, I just used the ones from the truck pan I took off.
Old 04-15-2012, 10:51 PM
chuckd71's Avatar
The muscle car pan hangs way down below the crossmember. Just something to be aware of.
Old 04-16-2012, 09:08 AM
99vette what kind of car were you working on? Do you have a part number for those mounts? Thanks guys for the replies.
Old 04-16-2012, 06:37 PM
99VetteFRC's Avatar
I bought those damn things like 7 months ago. I bought them from Summit for like $40. Downfall I shoulda ordered the 1" setback plates. There are plenty of pics on my thread in my sig.
Old 04-16-2012, 07:48 PM
FastKat's Avatar
The muscle car pan is a truck pan (not sure which truck) and it sits very low. The CTS-V pan does not sit quite as low, and is shaped a little different - the sump isn't quite as deep.
Quick Reply: cts-v oil pan and ls swap mounts?
