Where can I get valve spring shim spacers 1.437" OD, .645" ID x 0.120 thick & 0.160 T
Old 04-14-2012, 08:42 PM
Moderator
John B's Avatar
Default Where can I get valve spring shim spacers 1.437" OD, .645" ID x 0.120 thick & 0.160 T
I need to add aluminum spacers under my valve spring pockets that are 1.437" OD, .645" ID and I need them in two thicknesses; 0.120" & 0.160" thick....any idea's where I can get them? All I see are shims 0.015", 0.030" & 0.060" thick!
Old 04-16-2012, 05:51 AM
LS1MCSS's Avatar
I did a quick search and the .060 was also the thickest I could find. You may have to have something custom made.
Old 04-16-2012, 08:31 PM
Moderator
John B's Avatar
Thanks for checking!
Old 04-17-2012, 11:58 PM
studderin's Avatar
15 30 and 60 is std. you can stack them
Old 04-18-2012, 09:56 PM
Moderator
John B's Avatar
you can stack them
I know, I was trying to get away from stacking!
Old 04-18-2012, 11:23 PM
01ssreda4's Avatar
Monte looks good
Old 04-19-2012, 06:29 PM
Moderator
John B's Avatar
Monte looks good
Thanks!
Just wait until these 400+ CFM heads, solid roller cam, sheetmetal intake & 102MM TB are installed
