03turbomach1 vs cobranotch
This should be fun.... So Nathan(cobranotch) came by last night with his 92 lx coupe with an 03 cobra swap. Seems to run very well. I know it has a smaller pulley(don't know the size) jlt cold air, 3.73s. It has a/c and p/s, should know the weight on it today. He can give you more details.
I have a 03 mach 1. Has a mmr turbo kit and a t56. Race weight for me is 3480. Best 1/4 is 11.53@122.
Who do you think will win????
As soon as he gets it tuned we will post a video of the race.
coupe car (notch)stock eaton 2.93 pulley,off road x, jlt intake,3:73s, magnaflow cat back afco heat exchanger. it weighs 3200 with me in it. 2960 without driver. Will be tuned fri. 27th so ill have some numbers then. but need some seat time and rear end work before going to track. (still has stock axles)...... full upr suspension other than struts and shocks
I believe instant death of a Mach LOL
I've seen a Fox with the Terminator swap run 10.80's. Engine had a pulley swap, swap headers, and a cai. The car had a C4 and full suspension front and rear with 3:73's.
Should run good if he can put the power down.
I'm sure after hearing the weight and knowing what it should make at the wheels. He should have me covered, Im gonna have to swing in and weld some weights under that b**ch
I did forget this in my mod list full upr suspension. but stock shocks and struts for the moment.
