Conversions & Hybrids - Making DBW work in 98 Z28 with ls3 topend 370ci
ls1ya
04-17-2012, 03:02 AM
Putting together parts for my ls3 headed 370, what all do I need to convert to dbw? I already have the manifold, TB, injectors, fuel rails, and heads. I know I can switch to a cable TB but I want to be different. Can somebody post a direct link to a sticky or give me a list. If not how much is a stock ls3 DBW TB going for in classifieds? Cuz I got one for sale. Thanx.
garys 68
04-17-2012, 06:35 AM
What's the engine, ecu, and harness?
ls1ya
04-18-2012, 12:34 AM
An lq punched .030, going into 98 car. I don't have another ecu or harness trying to find out what all is needed
jmilz28
04-18-2012, 12:49 AM
You are making life unnecessarily difficult. You will need a different PCM, harness, DBW pedal assembly, TAC module...to start with. I'm sure there is more but that gets you most of the way there. This is not a good move...
garys 68
04-18-2012, 01:57 AM
The LQ is probably a 24x reluctor (you didn't sat what year). LS3s operate with a 58x reluctor. Sounds like your optopms are:
Get a 24x ecu, TAC, and harness, and a 4 bolt DBW TB adapter from Speartech.
Get an LS3 ecu, harness and a 24 to 58x reluctor adapter.
Go with the 24x ecu and aftermarket 4 bolt DBC TB setup.
ls1ya
04-18-2012, 03:26 AM
I figured it would be to much. But was curious. Thought I could source everything used for cheaper than DBC TB. How much can I sell my dbw TB for?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
