Fueling & Injection - Fueling to support 10-12 pounds of boost
jak2908
04-18-2012, 07:18 PM
Wondering if a racetronix pump and hotwire kit and 60lb Siemens deka IV's will be supportive enough or if I have to get 80's also wondering if I'll need a tune before start up?
01M6TA
04-18-2012, 08:43 PM
no way of answering with the info you have given. what is your setup. there is a difference between 10 psi on a 70mm turbo and 10 psi on a 88mm turbo. remember that boost is a measurement of pressure which is the resistance to flow. we need to know how much flow you are shooting for not how much boost. and yes you always need a tune before startup when changing injectors.
Lonnies Performance
04-18-2012, 08:45 PM
You will run out of pump before you max out 60# injectors.
Feel free to give me a call if you want to discuss a fuel system for your car.
I can set you up with a system that will support your power goals.
jak2908
04-18-2012, 08:50 PM
Whatever is stock on the basic sts rear mount Probably be goin to a t76 after that
jak2908
04-19-2012, 02:13 AM
Forgot to mention...ls1 that will have 9.5:1 compression
