Alternator Question
Old 04-19-2012, 08:12 AM
daniel044's Avatar
Default Alternator Question
I have searched all over the forums and cannot seem to find if it is possible to run a fbody alternator bracket and crank pulley only? Is there a belt short enough for that or will I need to buy the BMR alternator relocation to extend it? I will not be using a tensioner so I will need a exact length belt.
Old 04-19-2012, 09:41 AM
bczee's Avatar
You will most likely have to add a idler in place of the F-Body PS Pump to keep tension on the Water Pump Pulley.
Try a Search as other have posted some drawing or pictures of what they did for a Alternator only setup.
BC
Old 04-19-2012, 09:43 AM
daniel044's Avatar
I have no water pump pulley. Only pullys I have are the alternator and the crank. Everything else is electric.
