Power out of lq4
Power out of lq4
How much power are you guys
Making outta these blocks? I'm tryin to make 1100 I've seen a
Bunch of you guys making a ton of power with these, the setup I'm looking to go with is if you can take the blck to a 427 if that's possible, Callie's dragon slayer crank,Oliver billet rods, wiesco pistons. Heads are goin to be
305s power added is a F1R,so first and foremost can you take a lq4 to a 427 without weakining the cylinder walls and second can this block handle 1100hp without having to go to a Lsx block.
Thanks guys
Thanks guys
