Gears & Axles - Need info on rearend asap look inside
2000whitevert
04-21-2012, 02:20 PM
Tearing my rearend apart today n i cant get the cclip on the passenger side out the car has a torsen posi is there some sort of trick to this???? The driver side pushed in n popped out with no issues passenger side is being rediculous any advice?
sreve
04-21-2012, 03:07 PM
Tap on the axle with the BFH?
2000whitevert
04-21-2012, 03:47 PM
Idk what to do the cclip is too far down in its groove its moving around and everything just cant get it to fall ive never had this much trouble with this before its fucking stupid any1 that can help it would save me a lot of frustration
fastassls1maro
04-21-2012, 04:11 PM
Remove the wheel speed sensor to allow the axle to slide in further.
heymoej
04-21-2012, 04:40 PM
^^^^^^^^^^^^^^this.
FirstYrLS1Z
04-21-2012, 06:00 PM
3 situations will prevent the axle going in far enough to allow removal of c-clip
-4 channel sensor in backing plate
-axle bearing has been replaced by an 'axle bearing saver' assembly
-twisted splines immediately outside of the carrier splines
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
