Meth pump fittings
Meth pump fittings
Hey guys I need your help, I finished my turbo build on my car, but I'm having issues with my meth system. The problem is that my plastic meth lines are leaking and I want to run braided lines. The meth system I'm using is a used kit from Devils Own Injection.... I'd would greatly appreciate any help. I hope I can can get part numbers for fittings so I can order them asap. Ill post picks of my build soon
I used a special cutter for those lines and inmate sure they were all the way.... At first they won't leak but after a few trips around the block they started to so one again I check and they leaked.... I was testing with water only the pump is not activated only when testing... To make sure all fittings were leak free. And my nozzle is near alot of heat because of my setup... I don't know how to post pics
