superman2002
04-22-2012, 09:24 PM
I have 2002 z28 and looking to buy a new rear end 10 bolt has about had it.
I drive the car on the street for about 100miles a month. I also drag race it in lsx series and at my local track. It also gets at least 1 time a month at a autocross event and im lookin at taking it to a road coarse. Now that being said what rearend should i go with. 9" or 12 bolt and what differential posi, locker, wave trac, true trac etc...........
Bob@BruteSpeed
04-23-2012, 07:39 AM
http://shop.brutespeed.com/Brute-Speed-10-Bolt-12-Bolt-and-9-inch-Information-Brute-Speed-Rear-Information.htm
I have a lot of info at the above link that should help you out.
http://shop.brutespeed.com/Moser-M9-F-Body-Housing-Axle-Torque-Arm-Differential-Package-Moser-M9-F-body-Complete.htm
The Moser M9, which is Moser's fabricated nine inch, is about the same weight as the stock 10 bolt, so you would not be adding weight to your car. It comes with a chrome moly non binding torque arm and chrome moly transmission crossmember. On my Camaro this combination with M/T drag radials was cutting 1.29 60 ft times.
The Wavetrac differential was designed to handle 1000 hp and operates without you knowing it is back there, it is very smooth. For what you are doing with your car, the Wavetrac would be a great way to go.
These rears ship out two days after the order is received (allow 2 more days if you want it powdercoated) and the price includes shipping to your door.
Let me know if you have any questions. Bob
