ETP 215 11 deg head's need some input.
Need input on ETP 215's looking at a set. And i would like to hear from people running them. ??? What kind of power and what's your setup??? Its between thes and trick flow 215
Are those the same head as the PI 215 11 degree now sold by Mast?
Genuinely asking I do not know, but it seems likely. The published flow numbers vary a little but could be bench to bench variation.
Here someone compared them back to back against a similarly sized ported 243
https://ls1tech.com/forums/dynamomet...-gm-5-3-a.html
I believe they have similar origins.
To the OP - My set-up is in the sig and I'm happy with the way it performs - wanted max area under curve in a heavy, true-streeter, rather than top-end. Mine is done and dusted by 6250rpm and carries to 6500rpm.
cheers
