what rockers
Old 04-26-2012, 02:03 PM
hsvgtsr's Avatar
Default what rockers
i fear on or more of my rockers may be on there way out
what would be best to replace them with? 1.7 / 1.8 make?
i'am runing : ls1 c4b/eps 236/242 111lsa /kinsler itb intake manifold/ hsv headers/ 2.5inch cat back without cats
any advise would be grate
Old 04-26-2012, 05:28 PM
salemetro's Avatar
What lift and open spring pressure?
Old 04-26-2012, 05:59 PM
racer7088's Avatar
Probably OEM rockers would be fine as Geoffs EPS lobes are smooth and not over .600 lift usually.
Old 04-27-2012, 05:29 PM
hsvgtsr's Avatar
i'am only running a tad over 600 lift
is there any advange in runing 1.8 rockers?
Old 04-27-2012, 08:12 PM
Bramlok's Avatar
I would just use the stock rockers and do the comp cams trunion upgrade.
Old 04-28-2012, 03:09 PM
hsvgtsr's Avatar
thanks guys i've got a chance of some harlen sharps 1.8 rockers cheap
but if the standard rockers are good i'll put the set or oem one's i've got in
Old 04-28-2012, 04:39 PM
PREDATOR-Z's Avatar
Do not use 1.8 rockers. Your lobes are too sharp to have valve stability with those.
1.7 is the way to go.
Old 04-28-2012, 05:29 PM
hsvgtsr's Avatar
thanks mate will do i've got a set of standard oem rockers so i'll do the bearing upgrade
thanks again people
Old 04-28-2012, 09:18 PM
fastazzls1's Avatar
also increasing the rocker arm ratio increases lift at the valve thus decreasing ptvc!
