Conversions & Hybrids - 01 LS1/t56 into 95 chevy 1500?
yrydhi
04-28-2012, 07:59 PM
i recently came across a great deal on a wrecked 01 Z28 and was wondering what are the main things to consider if i was to try to swap the LS1 and t56 into a 95 chevy that currently has a non running 350 and 5 speed in it. I know bigger fuel pump is required.
brian.harmon1974
04-28-2012, 10:37 PM
The biggest things are motor mounts, exhaust and accessories. Depending on what u use for motor mounts the motor can move. Transdapt sells ones that put the back of the motor in stock 350 location. If you do that then most everything else should fit. A lot of the truck parts should work well if what u have doesn't. Also budget for parts comes into it, like if u can afford the swap headers and stuff like that
the_merv
04-29-2012, 01:04 AM
Look for the normal SBC->LS Conversion plates, there should be long tubes available for that truck now.. T56 will come out right infront of the seats.
yrydhi
04-29-2012, 03:19 PM
Thanks for the replies guys.....i may have found a mechanic friend willing to tackle this job for me haha....
scatillac
04-29-2012, 06:40 PM
Schoenfeld makes a nice header for your swap. They're full-length 1 3/4" LTs with a 3" collector and they work with TransDapt's #4572 plates.
Also, if you use the 4.8L truck or CTS-V pilot bearing and a 4.8L clutch/flywheel assembly, your LS1 will bolt right up to the NV3500 5-speed.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
