Please Help a Newbie Understand What the Stator Number Means
Old 03-27-2004, 05:34 PM
Brett H's Avatar
Default Please Help a Newbie Understand What the Stator Number Means
Just as the title says, I would like someone to briefly explain what the STR number on a converter means. Is a higher or lower number better?
Before I get a "do a search" I did and I couldn't find an answer.
To make things easy on me would a 2.5 STR work the best on my TA w/ 2.73's?
Thanks in advance for the help,
Brett
Old 03-27-2004, 05:43 PM
LS1TECH Sponsor
foff667's Avatar
its the total multiplication of tq from your engine through your tranny and sent to your rear via the driveshaft...the higher the # the harder it will hit the tires. Ive got a tci ssf 3500 2.5 w/ 2.73's for reference and dropped nearly 7 tenths in the 1/4.
Old 03-29-2004, 10:15 PM
Stone0fFire's Avatar
until someone who knows what they are talking about chimes in,
let me say low STR will generally launch softer but pull better.
higher STR will launch harder but not pull as hard.
why?
increasing STR through the traditional method
(whatever that is)
decreases efficiency.
so after the STR effect leaves
(which is soon after launch)
efficiency (or inefficiency) shows.
however, now some companies are using a 21-blade stator,
which supposedly increases STR while not reducing efficiency like the other method.
lastly,
higher STR will supposedly help alleviate some of the "looseness" from a high stall.
and i think increasing STR lowers shift extention, and vice-versa
alright, can someone else correct this?
