LT1-LT4 Modifications - HVAC Vacuum Line Check Valve Part #?
brocklt1
05-01-2012, 12:01 AM
A roof rat made a nest on top of my intake manifold and ate through some vacuum lines. So I need help finding the part number for the vacuum line that goes from the manifold to the check valve. This is the one in the pic below that says "to intake manifold:"
http://shbox.com/1/vac_check_valve.jpg
Also seen below under "to HVAC Vacuum check valve.
http://shbox.com/1/evap_sol.jpg
Thanks for your help and yes we shot the roof rat in the face :).
shbox
05-01-2012, 07:11 AM
The hose has no specific GM part number other than for bulk plastic hose (that you can buy at any auto parts store). If the elbows are intact, then you can just reuse them and replace the hose in between. If you need elbows, you can probably find them at a parts store, too.
brocklt1
05-01-2012, 09:12 PM
Rob, you are a hero, thanks.
