Kamron92
05-06-2012, 08:20 PM
I recently bought a 2001 camaro coupe with an a4, ls1, power everything, and it completely stock minus a slp lid. I want to turn it into a street/strip car with a budget. I've never messed with an ls1 before so everything I know about them was learned in the last 2 weeks. Here are my plans:
-Fast 102mm intake and Tb
-Texas speed PRC 227 heads
-magic stick 4 cam w/ 111 lsa
-performabuilt 4l60e
-3800 stall
-long tube headers
-30lbs injectors
-magnaflow catback
-high flow MAF
-4.11+ gears
-weight reduction
-suspension
Those are only the parts I'm sure about but please tell me if I'm making a combination error because I would rather everything work together so I can make more power for less money. Also as far as the rear end goes, do I need to go fully built 9" with a 4 link or can I get away with subframe connectors on the stock 10 bolt until it breaks then replace it? And would it be worth converting the power windows to manual to save weight? Please fill in ALL of my gaps. Thanks!
-3800 stall
-long tube headers
-30lbs injectors
-magnaflow catback
-high flow MAF
-4.11+ gears
-weight reduction
-suspension
