Trying to figure out witch heads to use on a turbo 4.8
So I have two sets of heads for my 4.8, one set of heads are stock 5.3 heads and the other is a set of stock ls1 heads.
I was plaining on using the 5.3 heads but I've been reading a hand full of builds and some are use the 5.3 with ls9 head gaskets and some are using the ls1 heads with l92 head gaskets.
I know that the ls9 head gaskets are 7 layer and the l92 is a 5 layer head gasket.
So now I'm lost on witch ones to use.
I would like to be running around 15 lbs of boost with the 70 mm on3performance turbo
So, what do you guys think would be the best heads and head gaskets for it??
241 & 853
Heads: 1997+LS1 5.7- liter passenger car
Combustion chamber Volume:66.67cc
Intake port Volume:200cc
243
Heads: 2001+ LS6 5.7 liter passenger car
Combustion chamber Volume:64.45cc
Intake port Volume:210cc
706 & 852 & 862
Head: 1999+ LR4 4.8-liter Truck
1999+ LM4 / LM7 5.3-liter Truck
Combustion chamber Volume:61.15cc
873
Head: 1999-2000 LQ4 6.0-liter Truck
Combustion chamber Volume:71.06cc
317
Head: 2001+ LQ4 6.0-liter Truck
035
Head: 2002+ LQ9 6.0-liter Truck
Compression Ratio:10:1
From this list I would pick the LS1 heads....
243
706 & 852 & 862
873
317
035
And don't do exactly what he does - He has already chucked an axel on the highway and trashed one car.
241 & 853
243
706 & 852 & 862
873
317
035
243
706 & 852 & 862
873
317
035
I'd use the LS1 heads. I bought a set for my 5.3 project. It drops the compression a little so you can push more boost and has bigger intake valves for better flow.
And yeah his videos crack me up!
