minimum ptv clearance ?
Whats the minimum ptv clearance on intake and exhaust side. Running 243's milled .010 on a 6.0 bored it .040 with flat tops. Cams a 224/230 .609/.604 on a 112 lsa intake cl 108. Running 7.4 pushrods. Machinst says for his calc. With deck heigth as is pistons protrude just a little bit no more than. 020. Wanna run stock gaskets with bore diameter of 4.100 and a thickness of .041 .any issues n that stand out b4 i order gaskets? They also come in .053 thickness. Im gonna clay and check but wanna have gaskets on hand so if all is well i can go ahead rite then and bolt heads on .
Thanks
Thanks
