Factory Grille
Old 03-28-2004, 09:04 PM
domesticracer's Avatar
Default Factory Grille
Is there a way to get the fatory grille off without removing the nose of the car and without breaking the grille? And, i live in texas so i have to have a front license plate, so if i removed the grille is there any way to get the lisence plate on there. Im scared to just pull the thing off cause im afraid ill break it.
Old 03-28-2004, 09:14 PM
Sigler's Avatar
Default grille
i had to cut mine off and i didnt spend the long hours it looks like it takes to remove the front nose to unbolt it off. i live in texas and have had the car for 2 years and only got 1 warning for no front plate. i am going to put it on my lower flap that hangs down under the front nose under the radiator. good luck
Old 03-28-2004, 09:17 PM
cut.....doesnt sound good would i be able to put it back on... ive heard you can just pull it off but it still sounds like every one has broken it
Old 03-28-2004, 09:30 PM
Silly02SS's Avatar
i just pulled mine off and it didnt break
Old 03-28-2004, 09:34 PM
Rick'SSOM's Avatar
I just pulled mine off too, no problem.Did it on a hot day.
Old 03-29-2004, 04:01 AM
Cummins's Avatar
Ditto, just grab and yank
