315s on a stock 17" ws6 wheel
Old 05-12-2012, 09:12 AM
Leeroyws6's Avatar
Default 315s on a stock 17" ws6 wheel
what do i gotta do to be able to run these tires succesfully? i heard you have to pound the inside of the fenders witha hammer to gain clearance.
Old 05-12-2012, 09:21 AM
LS-ONE_DAY's Avatar
https://ls1tech.com/forums/wheels-ti...must-read.html
Post #1
You can get it to work if you have a company modify the wheels to widen then, but it's usually at least $200 per wheel from what I've seen from the hand-full of people who have done it.
Banned Scammer
BashamWS6's Avatar
295s max on a stock tire
315s are more 10.5" or 11" wide
Old 05-12-2012, 09:25 AM
Leeroyws6's Avatar
ok thanks.good to know. i thought i read somewhere people were mounting 315s to a stock rim.i might be wrong though.what i dont know could fill a library!
Old 05-12-2012, 09:28 AM
Leeroyws6's Avatar
holy crap!just read the sticky. i apologize for asking this question!
Old 05-12-2012, 09:56 AM
99zee's Avatar
There are some that do. Do it right on a 10.5/11 wheel. It's safer and looks better
Old 05-12-2012, 10:46 AM
1999transamls1's Avatar
when i bought my ws6 wheels they had 315's on them, wouldnt recommend that at all, bulges a TON.
Old 05-12-2012, 11:11 AM
Douchebag On The Tree
justin455's Avatar
It will look like this...
Old 05-12-2012, 12:09 PM
Camaro396's Avatar
That's actually a 17x8 wheel, but would be similar. People have put 315 Nittos on stock 17x9 wheels, but Nittos 315 tire is similar to any other tire manufacturers 275 tire.
Old 05-12-2012, 02:57 PM
NVR_SPDS's Avatar
Ive had 555Rs and 555s and I wouldnt recommend mounting either of them on a 9" wheel. Even my "narrow" 555Rs were still about 11" wide. The 555s I have on my car now are about a full inch wider than that.
Old 05-12-2012, 08:22 PM
Marc 85Z28's Avatar
I've had the 555R 315/35r17 and 555 285/40r17. They're the same width!!! Furthermore, I compared them to a 285/40r17 GSD3 I was putting on a Corvette - the Goodyears were nearly 1" wider than the 315 Nittos, not mounted. Mounting ONLY the Nitto 555R drag radial 315/35r17 on a 17x9 is fine.
Old 05-13-2012, 12:56 PM
redtan's Avatar
You realize that most 275 tires are about 10.9" wide? And plenty of people say that 275 will fit on a 9" wheel, so your 315 555R is about as wide as most other 275 tires that fit just fine on a 9" wheel.
Old 05-13-2012, 02:06 PM
AChotrod's Avatar
Im not telling you to do it, but look at my sig for 315 nitto DRs on a stock rim.
Quick Reply: 315s on a stock 17" ws6 wheel
