Car won't start after holley dominator efi install
Old 05-12-2012, 02:03 PM
ss_girl's Avatar
Default Car won't start after holley dominator efi install
Looking for a little help here. I think I got all the initial configurations correct but my car still won't start. It will start for just a second and go back out.
Car is 408, 91mm turbo, 3 bar map, 96lb injectors
Old 05-12-2012, 03:20 PM
ss_girl's Avatar
It appears only the odd cylinders are firing. On a side note my wiring doesn't match the diagram. I have a loose blue/white striped wire but no white or yellow as shown in the diagram if that helps any.
Old 05-14-2012, 03:57 PM
HoP
HoP's Avatar
I'm assuming you have the ecu set up / configured for 8 cylinders?
Old 05-15-2012, 07:23 AM
Old Geezer's Avatar
SS... Check your pms..
Old 05-16-2012, 01:29 AM
bmf5150's Avatar
What custom tune u start with?
Quick Reply: Car won't start after holley dominator efi install
