Thinking of doing TSP TD<'s....questions
Okay, i boguth my 02 SS with a corsa system on it. too quiet for me. i have emisiions here, OBD-2, i have 2 years until my next test so now is the time.
I want to pair pacesetter LT race styles wit hthe true duals. It says it does not have EGR provisions, do the 02's even have EGR?
also will my air system be messed up? Iknow i will be deleted my cats, so i will be smog illegal, will a mailorder tune from FROST be able to be enough to delete the codes and keep it running smoothly?
i have ahandheld tuner, would he be able to send me the tune to be used on that software? it is a flashpaq
since ill be dumped before the axle, how much ground clearance will i be losing?
thanks guys!
thanks guys!
The Scammer Hammer
Delete the AIR. Frost tune will keep the codes out and let you pass OBDII
Look in the true dual sticky. It all varies with how much time you're willing to spend setting them up.
01/02's did not have EGR but they did have AIR, also I'm sure Frost could turn the system off and handle all of the other things that you mentioned as well. If you're at stock ride height I don't think that the dumps are going to effect your clearence very much if you set them up properly.
From my understanding, you will either have to literally yank it out of there and get block off plates for the headers or have a tuner turn the system off completley
