mcleod aluminum flywheel
hi everybody
i found this ad and bought one of these today. plus it's the Al model, i didn't even know they made one.
i called mcleod to order it and the price is real!
http://www.racingjunk.com/Clutches/1...el-Chevy-.html
Cheers!
Cheers!
If you're doing an LS conversion with an old school trans, Muncie, T10, TKO, Richmond 5/6 speed, etc, the 0.400 inch moves the disc back so the splines dont run off the front of the trans input shaft.
I dont know if the hydraulic throwout bearing on the LS1 T56 can be shimmed back enough to use this flywheel though.
